StevNimrod
- Joined
- Dec 13, 2008
- 343
Re: Oil in water...getting it out
Intake is off.
Ran pressurized water to the intake before pulling manifold and got same results as before (water occasionally dribbling out of #1 spark plug hole). With the manifold off I could see a little water sitting on top of the #1 spark plug hole. Not sure if that helps point to/eliminate anything but thought I'd add it. Just seemed weird to have water occasionally dribble out of spark plug hole then find it on top of intake valve.
Checked the gaskets and couldn't really tell anything. They're plastic type with seals around ports so there was no impression to check like on the paper gasket. It did look like the machine shop may have laid the bead of silicone down before placing the gasket, and there did not appear to be any thread sealant on inner intake bolts.
I'm thinking about switching to a FelPro paper gasket since I'm not sure reinstalling the same gasket would result in any difference.
Also, the block got decked during rebuild; not sure if I said that before but I'm trying to get all of the details on the table.
Thoughts?
Intake is off.
Thoughts?
