Re: One thing after another...
first,slow down,you parts chnging way too fast,no disrespect.you say you accidently started it and it ran decent,then you say it didnt cool,when you accidently ran it did you have water to the eng.if not,you probably heated the impeller and its history,you say you lost spark again,well,i agree with the post that says your key switch is suspect,it happens alot,as the keyswitch sends ground to kill the packs,you had trouble on one side,that could indicate a pack,a pack does a bank,you also have neutral safty in control box that could give u trouble,what 2 do first,get a spark tester,pull all plugs,disconnect the main harness,the red plug,jump positive to the starter,as eng cranks check your spark tester,WAIT,be sure no fuel goes to engine because as it blows out thru plug hole it could be ignited by the spark tester,you will likley find spark,then proceed to the keyswitch after hooking red harness up, making sure all wires connected are not touching anythin,especially the black one with yel stripe,disconnect the blk/yel and check 4 spark,if you have spark,your switch is likely bad,but you could have a bad harness,so disconnect the plugs from the packs with the black/yel wires,with the black/yel back on the terminal on the switch see if you have spark if you have spark trouble in the harness,i have seen corrosion buildup in harbesses that allow enough grnd to kill or give problems,take it slow,ask alot of questions,i enjoy this ,as many do,we all lean together,idea is to save money,not spend it on un needed parts,we will get you goin,dont worry about that,patience ,dont be concerned with compression right now
