Re: One thing after another...
The melted stuff you mentioned is a CLEAR indication your Stator is shot, its the varnish/epoxy melting , Its easily could have been detected had you use a flash-light to lookup under the flywheel. Reason I mentioned this is because on another blog a PRO give hell me for even mentioning this simple troubleshooting step.
I did NOT and it cost me dearly !
I have since arrive to the conclusion,If you have a electrical issue check your source and work your way out, Trigger,Stator,Pack,Wires,Coils,Plugs..
I have experienced the very pain you going through, hang in there you will nail it.
If you can afford it replace both the Trigger and Stator you will not regret it.
Good Luck , I am sorry I did not follow up on this post ..
