Re: Reasearching new TV
I purchased a 47" Vizio 1080p for $1000.00 and could not be happier. It has excellent viewing from any angle. I run regular cable through it and the picture is great but it was a hassle getting there, more on this below. Where my tv blows me away is when I watch a movie using my upconversion 1080p dvd player. I cant wait to get true BluRay but I don't see how the picture can be so much better than my upconversion.
I have lived in my condo for 2 years. The cable was always fuzzy and I thought it was just weak poor signal. I did all the things the internet recommended. Purchased the best splitters from Radio Shack and purchased the best cable signal amplifier. All this expensive stuff did was make my fuzzy cable more fuzzy. My cable and internet are the same provider. I was having trouble with my internet that I could not resolve so a tech came out. He tested my signal and said it was better than average and quite good at the main line. He went down my lines testing at each split telling me the signal strength as he went. The very last split the last little 3 foot cable he says yep here it is. I had a bad cable allowing all kinds of interference into my signal. This cable was one of those little cables you get when you purchase a vcr or dvd player. It is the kind with the push on connectors instead of the screw on kind. He said it is a very common failure as these cables are made cheap. He pulled new cable out of his bag and made me a custom one on the spot. My tv experience improved ten fold. I am mad at myself for living with the poor signal because of a stupid cheap $3.00 wire. Because of this new cable I was able to remove one splitter and the amplifier from my signal which only made it better still. I guess what I am trying to say here is check all your wire runs and switch out wires to eliminate any problems. Heck the cable, connectors and a crimper are so inexpensive you may want to consider running all new lines if you are going to buy a $1000.00 tv.
