Starcraft Fishmaster 190 REDO
SPLMAXSAM
No Title
Installed a Minn Kota Ipilot today along with Uniden marine radio.
Tuned up, painted and replaced rotted wire on mercury outboard
SPLMAXSAM
Removed the sun faded torn vinyl from the gunnels. Painted them with truck bed liner material tinted 054.jpg 024.jpg to match the rest of the color scheme
SPLMAXSAM
Installed 2 bilge pumps and new live well pump. 1 bilge pump has a float switch. I added a buzzer and light to float switch to console to indicate high water in boat. The other bilge pump and live well pump are wired to on off switches on the cluster.
SPLMAXSAM
063.jpg 069.jpg 086.jpg I
Installed some power. 10 hp kicker motor and 140hp Merc
SPLMAXSAM
No Title
Took a break from boat building and went fishing with a couple out of state buddies. Ended up with a couple of nice ones
Watermann
Super good eats there, some nice sized eyes. :hungry:
SPLMAXSAM
Lucky enough to live near spectaclur fall fishing. Maybe best in North America. Currently we have a heavy nite bite going. Lot of 8-9 lb fish. Some going 12lb
SPLMAXSAM
No Title
Wired in dual battery tester for 24 volt trolling motor. Can test each battery individually.
Wired in dash lights
SPLMAXSAM
My goal is try to splash before 12/21 and include serious fishing attempt. Want to try to break the boat in on a big one
SPLMAXSAM
No Title
I designed a circuit for my bilges. I wanted an indicator either visually or audible to indicate excess water in the boat. The intention if water is higher than desired the indicator would be triggered. I upgraded bilge to 900 gph and increased the hose size to 1"
SPLMAXSAM
No Title
The transom has been reshaped. I love to fish and I now realize I am going to want a work area to prepare fishing lines, unhook fish, etc. So my plan is to trim the transom in FAKE wood and double up on the center part. That should give me a 11" work area
Watermann
11" area, not very optimistic on your catch size. :lol: JK
That's the great thing about rebuilding your boat, you can make it how you want it with your imagination being the limit. Like your cooler idea and I put an in deck cooled into my SeaNymph's front casting deck
SPLMAXSAM
How big is the sea nymth cooler? Do you load it in from the top?
SPLMAXSAM
No Title
I replaced the fuel sending unit and i eurothaned the bottom of the boat. The rest of the tank was in very good shape
Frey0357
Nice build SPL...
I like the bilge plan you have created. I like the idea of alarming if the water level rises! I will look to use something like this in my build. Thanks for sharing this build, you have helped me on something I did not think of!
Frey
Watermann
Built in cooler that just looks like a hatch. I used the lid with AL sandwiched between ply for more strength. Forgot to add that I think it's 36 qt.
SPLMAXSAM
Attached is a video link showing the High Water Alarm
Hope that helps
