Gibbles
- Joined
- Nov 14, 2009
- 2,050
Re: Starcraft SS Specific Transom Replacement Questions: My Rebuild Project
To late, but I had the same problem but I used foam as a backing
I then had the bright idea to use wax paper, stuff works great and comes off with out any issue!
I did the final coat on my transom last night and put wax paper over the whole thing, mostly to prevent dripping, and to help fill in voids
Well some good news and some bad news.
Good news is the epoxy set very well and everything is tight. The bad news is my clamp idea had a major flaw. The 2x4's also laminated to the transom board. When removing them they pulled big chunks out of the top layer of the plywood on one side. I am not starting this over and feel this is nothing more than a cosmetic issue. I plan on running a barrier around the edge of the board and filling the holes with epoxy to level them out. Then I will sand and paint the epoxy. I had to paint it anyway as it will be exposed to the sun. More than likely I will not have enough epoxy now though. I'll have to order another batch.
If I were to do it again I'd run a sheet of foil along the 2x4's between them and the transom wood. Oh well. You live and you learn. Everything was going so smoothly up to this point I had to hit a snag somewhere.
Just going to do some odds and end thru the week until my epoxy gets here. I may get around to drilling the transom holes today. We'll see how it goes.
