Re: Starmada Testing Laboratories
OK, looks like I had it exactly backwards;
Subpart F - Flotation Requirements for Inboards, Inboard/Outdrive, and Airboats
FEDERAL LAW
183.101 - Applicability
This subpart applies to monohull inboard boats, inboard/outdrive boats, and airboats less than 20 feet in length, except sailboats, canoes, kayaks, inflatable boats, submersibles, surface effect vessels, amphibious vessels, and raceboats.
Discussion:
Monohull inboard, inboard/outboard boats and airboats less than 20 feet in length must comply with a flotation system called Basic Flotation. Basic Flotation contains the requirements and tests. Basic flotation is the simplest type of flotation mode covered in this regulation. It simply requires that the boat be manufactured with sufficient flotation material to keep it afloat in the event of a swamping. It does not, however, require that the boat remain in an upright or indeed any specific position. It may float, and usually does, in a "spar" position, the bow sticking up and the stern sunk. The requirements include some materials tests. Basic Flotation covers this type of flotation.
Subpart G - Flotation Requirements for Outboard Boats Rated for Engines of More Than 2 Horsepower
FEDERAL LAW
183.201 - Applicability
(a) This subpart applies to monohull outboard boats that are:
(1) Less than 20 feet in length; and
(2) Rated for outboard engines of more than 2 horsepower.
(b) This subpart does not apply to sailboats, canoes, kayaks, inflatable boats, submersibles, surface effect vessels, amphibious vessels, and raceboats.
Discussion:
Monohull boats under 20 feet in length and rated for more than two horsepower must comply with the more sophisticated flotation system called Level Flotation. The Level Flotation system requires that the swamped boat, loaded with certain weights representing weight capacity, part of persons capacity and some equipment, must float in an approximately level position and not heel past a certain angle, even when part of the passengers’ weight is on one side of the passenger carrying area. The Level Flotation section covers the requirements and tests to perform.
For all of you techno-weenies-Here's some bathroom reading...
http://www.uscgboating.org/regulations/boatbuilder_s_handbook/flotation_part1_a.aspx
