Re: the 1967 Holiday 18 and Multiple Boat Syndrome
Too much progress and pix for one post so I’m going to break this up
I dream of a big head rider
she got 4 cams, and valves and chains
yes I dream of a big head rider
with 4 heavy cams, all them valves and chains
but I can tote her easy
got badazz kneee braces under them splashwell drains........
THE KNEE BRACES: this has been a major since I need to get the transom done before I can do a bunch of other stuff on boat. I got the Lone Star sections bent up for the stringer bracing but needed to get it finally drilled and all put together. Once again, you gotta love a drill press when you can easily put a perfect 90 degree hole through both sides of a 2" box section tube
first pic shows things roughly lined up. You can see my precision line for where the Lone Star section comes to on stringer.
[/URL][/IMG]
The outboard brace in position on the stringer but not yet riveted to ribs
[/URL][/IMG]
each of these 7 holes involved drilling through roughly .325" (about 8 mm) of aluminum; the tedium had to be experienced to be believed, esp once the bits got dull. Neighbors no doubt also loved the sound of air drill on 18' alum resonator. Had to use the air drill as couldn’t get the cordless in there.
[/URL][/IMG]
Process also involved a million niggling little clearance trims.....mark, get out of boat, cut, get back in boat, repeat
ad dispiritum......... For a lot of em, you can’t see the next cut til you make the last one and test fit things.
[/URL][/IMG]
a view of one of the Lone Star sections, riveted in place on outboard side of stringer. You can see how this ties knee brace to last 4 ribs as well as stringer.
Closer pic from same angle
[/URL][/IMG]
anyway, thus endeth the saga of the aux knee braces. I’m super happy with the result. Stringers are rock solid, even before the floor is put in; before, they flopped around when I sat on floorboards. About $100 but could be done for much much less with scrap aluminum.
