Re: the 1967 Holiday 18 and Multiple Boat Syndrome
ahh, the white legs o death fit fine in there. now when i take my 215 lb fishing buddy, it gets a little more cramped. and you can't even see the kicker, large kit of flares etc, and ditch bag under the closed bow....
thanks for all the kind words. great progress this weekend, glasser on Saturday and tinnie on Sunday. we got sailboat running rigging replaced, bow eye removed and rebedded (this took some cutting of interior panels to get at backside), new tiller installed, kicker bracket installed, and keel winch removed (we were gonna just replace cable until we noticed that drum had rusted out and collapsed). Basically she’s splash ready once we bolt in new keel winch and check the trailer bearings.
then on the Holiner, got the transom in and lined up perfectly. i chickened out on bolting it in, since i figured it will be a lot easier to squirt a little paint on her butt if i'm not dodging 30 bolt heads plus a swim step and kicker bracket.
added a bunch more strapping to hold the conduits in place altho i'm still not happy....the big one can move slightly and that bodes poorly for longevity of rivet points. Another go at it tonight.
made up bracing for under the antenna base....;.this won’t get installed until console is in boat, as otherwise it would stick up and tear a hole in the cover
[/URL][/IMG]
[/URL][/IMG]
mounted the underwater light on the bottom of the swim step. One of my extravagances, but I suspect the Admiral will like it for night diving.
[/URL][/IMG]
Cut and rough fitted my cheep carpet....two throw rugs from the Despot, total about $20. I can already tell this will make a huge difference in noise and comfort, and it’s not even glued down yet. I also like the color, as the light beige reflects light to help with “cave” aspect under the bow. Plan is to only tack it in a few spots in case it needs to be replaced ....not exterior grade, AFAIK. Propane torch from back side of carpet worked great to seal cut edges against unraveling. as you can see, i still have a couple of cuts to make but want to get floors etc in first.
[/URL][/IMG]
Installed a string of killer LED lights I got from a friend inside the cabin.....these light up so bright that you almost need sunglasses to look at em! These will let me read or tie up leaders at night. another string will live under the rear splashwell.
[/URL][/IMG]
