Re: Water Fuel separating filter
Huh ?
We have found that, even with the portable 6-gal tanks, if the vent is left open (some want to do that to keep the tanks from swelling up like a throw pillow in the sun -- even though I recommend it be closed and out of the sun), there can be a tremendous accumulation of water in a short amount of time.
What happens is that as the tank warms in the day and cools at night, air, with very high humidity, (since it is on the boat at lake level), is drawn in and expelled from the tank in a daily cycle. During cooling, moisture condenses in the tank. Also, the E-10 fuel, which really loves to absorb water, grabs the water right out of the air. If allowed to continue to the saturation point of the fuel mix, the E-10 fuel then phase separates as the water and alcohol drops out. The lower the fuel level (more air in the tank, and more air exchange) the worse this is.
FWIW, the resulting gas, floating above the water, is a significantly lower octane, since the alcohol (the addition of which raised the octane) drops out in the water mixture. So even after removing the water, the gas is lower octane.
Running a water-separating filter will catch the water, and, while the phase-separated gas that remains, and passes through the filter, isn't the best, it's a lot better than trying to run on water.
We have also found that running a good gas stabilizer, such as K100-MG helps the gas stay together, rather than separating.
