waterline on boat
metalmanbc2000
I have quite the waterline on my boat. I just bought it off an older fella and he left it in the lake for 2 years. I was wondering what kind of advice you could give my as far as getting rid of it.
meals on reelsjello2
Re: waterline on boat
more than likeley the foam under your floor is waterlogged ......cut a hole in the floor in the middle and check the foan and floor ....i just got mine a month ago and after removing the floor the foam the stringers and the transom...just with that i removed about 600 lbs of water weight from my boat and it sits allot higher now and faster;)
metalmanbc2000
i plan on pulling the floor up in the next couple of weeks anyways so ill check it then. I have been looking around the forums and i think you might be onto something with the foam. the boat lists to the left quite bad so i imagine the foam is saturated. What kind of foam is the best?
Huron Angler
Hey metalman congrats on the new rig:)what kind of boat is it that you bought? If you have pictures it will be easier to get help. Also what is the length, aluminum/fiberglass?
metalmanbc2000
I actually don't know what kind of boat it is. I was going to post pictures but the files are to big and it won't allow me. Its a 16.5 ft fiberglass. The boat has no markings or indentification numbers of any kind which i thought was kind of weird. I do know it has a 82' 70 horse evinrude on it. But thats about it.
:cool::cool:What kind of foam is the best?[/QUOTE]
i use great stuff others will tell you not to but if you seal the floor well enough and dont have any leaks underneth it will do just fine///as for the id number it should be at the starbord side aft on the transit erea......my boat is my avatar....nice but getting majorly overhauled:eek::cool:
metalmanbc2000
I was just out looking at my boat and saw that there is a hole coming out from under the floor at the back of the boat. it is about the same size as the plug hole and located directly in front of it. My question is ... should that be there or is that a good indication someone knew there was water in the boat and decided that would be the easiest way to get rid of it? p.s. what is the name of the foam you use reelsjello2
i also had holes in my boat best thing to do if its under the waterline and you replace the transom fill them in and forget about them the foam is called Great Stuff..you can get it at your local hardware store or even walmart....its expando foam... when you get all the rot and old foam out let me now and ill walk you through the prossess we will post so everyon can benifit .....how much did you pay for the boat if i might ask????:redface::redface:
as of knowing if it should be there id have to see a picture of i .....but if its under the floor(deck) line then cover it up
metalmanbc2000
i paid 1200 for the boat. I figured it would be a good starter boat for me. I wish i would have known more about them before i actually made a purchase. But live and learn i suppose. The motor runs great and has great compression so i suppose i didn't get a bad deal. I'd post some pictures but all that ones that i have are too big. and the hole is below the floor so i will cover that up asap. Thank you for your advice.
next question did yo get the trailer too.......try running your picks through paint in your accesorys program from your start menue and lowering your pixles or file size .... 1200 you could probably get that out of the motor ...not a bad deal but more than alot of peaople would have done... dont get descouraged with a little work you can have the boat of your dreams..thats what im doing when i boght my boat i paid 300 and the trailer is worth 700 alone ....engine 60hp johnson runs like a dram...1500 ... but like i said dont get discouraged in tnese forums you can do the work yourself...give you something to do.. and be proud of your work.. and you can coustomize the boat to what you want
im doing a major costomosation to my boat and as soon as i get a cable for my camera ill be postin pics ....im even going to put a hartop convertible with a extendable foof on my boat because when i camp i sleep on my boat and im making it a boat/camper (i hope) and cool as hell ....but everything im learning im learming because of these people in these forums....
my email is davidleithoff@rocketmail.com please send me picks...
:p:p:p:cool::cool:
dont get discourged;; Meals On Reels.........(thats actually the name of my boat LOL!!!!
ezmobee
That outboard you got is one of the best ever made. Take care of it and it will serve you well. Should also be good power for a 16.5'. Chance are good that your hull is waterlogged. If it was mine, I'd rip it all out and see what's doin' under the deck. I'd replace the foam with the pink or blue sheet foam from Lowes/HD. Like this: http://forums.iboats.com/attachment.php?attachmentid=32838&d=1247487835
Best way to post pictures is to create a free account on photobucket.com and upload them there. That site will even let you resize them to the forum-acceptable size of 640x480 with a simple click.
esobofh
Are you talking about a mark on the hull you want to clean off?
Or are you saying the boat is sitting to deep in the water?
pinecrestwoods
Are there pics I'm not seeing????? I clicked on this thread because I thought it was a "how do I get the scum off my boat" post, and the first thing I see is talking about cutting out the floor?!?!?!?! Was there mention of a soft floor that I flew by? (certainly possible). "Holes in the back of the boat".... is this through the floor on the inside of the boat, or through the transom (vertical "back" of the boat)??? Are these holes that are rotted through, or are they brass, or what??? REALLY need some pictures here asap.... I think things may be getting far ahead of where they need to be.
Couple things of concern:
OP mentions listing. Def. needs some investigation- again, pics in water would help.
OP is planning to remove the floor- why? Is it soft? Or is that just to check out why it is "listing"?
Email your pics to Meals on Reels and have him resize/post for you.
Could very well need some floor and foam surgery, I'm not saying it doesn't.... I'm just saying you might want to slow down a smidge. More info, please.
marine4003
If all your trying to do is get rid of a scum line then use TSP..buy it in any hardware store for 5-6 bucks..apply with a spray bottle (keep it wet) goodbuy stains..
Numlaar
This really depends on the design of the boat... some are "supposed" to be there, sometimes they aren't...
I have a 15' Riviera Bowrider, that doesn't use foam between the outer hull and floor for the entire boat, it has two of those drain holes on either side of the keel to allow water that runs anywhere under the floor deck to purposely drain to the tiny little bilge area it has... they are also the same size as a standard drain hole (1"). If I were to plug them up, then water would just sit in the bottom of the boat, and rot out the floor... (thats why I already had to re-floor it once).
If the design of the boat uses foam under the flooring, then you probably wouldnt want them there, as it will just allow water intrusion into the foam.
Best thing to do like mentioned, is to post some pictures of what you are referring too... but if you are planning to pull the floor up anyway, you will get a better idea of whats there and what to do.
Splat
My thoughts exactly!!!!!!!
This thread is like the blind leading the blind and nothing but torn open hulls and big $ at the end of it. Lets slow down here and explain a some more.
Bill
Splat
Also the list could be as simple as prop torque. Since he mentions it leans to the port. At least I think he means port, he did say left.
Bill
metalmanbc2000
Lol i meant port and i did say left. ( not quite up on my nauticle terms..first boat) and i was looking at my lower leg today and realized that the very bottom..the peice i assume that acts as the rudder is bent and a little bit twisted. i don't know if this could explain why i am listing or not. Sorry for the cluttered thread. this is also my first time belonging to a forum. In the future i will try and stay on topic. Sorry all. here are a coulple of pictures as well i will post more later.
metalmanbc2000
i just went and drilled a hole im my floor! GOT PROBLEMS. First of all its a floor over the original floor. both layers of plywood and fiberglass are completely saturated in water. I also couldn't find any foam in there. The drainplug that comes from the bottom of the floor into the bilge area is definetly supposed to be there ( it has thread's in it) im not sure where i should proceed from here. Any advice would help.
