Smokepole27
- Joined
- Jan 12, 2010
- 162
Well it all started with changing the seals under the water pump houseing, well then come to find out they dont make the spring looking seal for the shift rod, so I had to order an entire new assembly, ok so thats not the problem now that I have that Im looking for some good advice on the 2 shiftrods they sent with it.... Due to the new assembly not haveing adaquit space for the old rod with the adjustment to go through it I will have to replace the rod.
Now with that being said, has anyone had expeirence with this new setup? Im really confused, am I really going to have to take this entire lower unit apart to replace this item? And if I do what tools will I need?where to get them? Alot of expert advice here PLEASE.... Also any idea how to adjust the shift rod after this is done?
