You can of course, put in what ever you want.
If the engine doesn't detonate on 87 octane fuel, you are wasting your money buying "higher test" gasoline.....Higher octane does not mean higher quality (even though it is and always has been marketed that way)
Higher octane gasoline will only prevent detonation in high compression engines. (which will make more power BECAUSE of the higher compression and advanced timing, NOT the higher octane)
If your engine doesn't require higher octane fuel, higher octane fuel will only drain your wallet faster.
No retail (on-road) gasoline in the US contains tetra-ethyl lead. (except 100LL AVGAS and OFFROAD "racing" type fuel) Sunoco below.....
Actually the bottom line is still
this from Mercury.
Regards,
Rick
