What sunglasses you recomend
v8psp
Just curious wat you guys think are the best glasses for the money. I see alot of people with Costas but they have so many models I have no idea what I want. What do yall use to get rid of the glare?
cbavier
Re: What sunglasses you recomend
I've been looking too and I am leaning towards Polarized from Bass Pro Shop.
The ones you wear over your prescription Glasses. My Optomitrist wants $250 for Prescription Polarized Glasses. I don't think so.....:rolleyes:
Mark_VTfisherman
I have a pair that cost about $22 at Wally Market. I like them and only use them for fishing.
cbavier
Are they Polarized ?
Do you wear them over Prescription Glasses?
Can you see into the water at shallow depths of course?
tunes
my mom had cataract surgery. They gave a pair of these huge dark glasses. They are big and have the side curtains on them. You can wear them easily over prescription glasses and they work great. I found them in a couple of mail order catalogues for about 10 bucks.
v8psp
Now guys, Im in college so I dont need no ugo glasses haha. Im jk.
I think I'm gonna stop by Bass Pro Shop and see what they have
dingbat
You don't have to spend big bucks on sunglasses but don't go cheap either. Whatever you get make sure they protect 100% from both UVA and UVB rays.
I used to use just any old polarized glasses. My eyes used to hurt after a day out on the water. A friend of mine talked me into a pair of Maui Jims. No comparison. Not cheap, but well worth it if you spend a lot of time on the water.
Huron Angler
http://shop.seastriker.com/sunglasses.html
These are some quality, low-cost, polarized boating sunglasses that float in case they go overboard.:cool: I've owned the "Skipper" model and highly recommend them to any boater. They will let you see thru the glare and into the water in calm conditions.
marquette
i have used Ray Ban and Bolle' when i used to be able to wear contacts. since i have gone to glasses i have tries several polarized clip on type and a pair of fit overs. none of them are as good as good sunglasses for cutting glare or seeing into the water. my son uses Costas and flats fishing in january he consistantly was able to see fish before i was or if i was able to see them at all. i think any polarized glasses are better than none but there is a reason the good ones cost a lot more it's because they are better. you just need to decide what fits your budget and level of need. if i was on the water 3 days a week then $300 for good sunglasses would be a necessity. if i was on the water 1 day every 2 weeks then $30 glasses would fit the need.
mike64
I'll offer a little different viewpoint: I go about as cheap as you can-- I go to the dollar store, find a pair of wraparound glasses that fit my face well, and buy 2 or 3 at a time. I'm always losing or breaking sunglasses.
These days even the cheapest sunglasses should offer UVA-UVB protection and often polarization too. Even the dollar store sunglasses will have a tag or a sticker saying whether they offer UV protection and polarization.
Obviously this won't work if you have prescrip lenses, but if not, why pay more? I used to buy expensive sunglasses and lost 'em enough times that I learned my lesson.
fishingman220
i bought a set of calcuttas at a marina, and they are polarized and they work awsome, and they were only $14 and look just as good as my buddies $220 coastas
dingbat
They're your eyes. You can buy as cheap as you want.
Addtional info.
Sunglass standards for lenses place limits solely on UVB and UVA rays, but bear in mind that both the standards and labeling are voluntary, not mandatory. According to these standards, sunglasses must block at least 70 percent of UVB and at least 60 percent of UVA.
To best protect your eyes, look for sunglasses that provide at least 98 percent protection from both UVA and UVB rays. Some of the higher-priced products with polycarbonate, glass or plastic (CR-39) lenses can claim to block 100 percent of the UV rays.
Something else to think about. Polarized glasses are also not created equal. I've found that when wearing some polarized sunglass I have problems seeing LCD displays. The problem isn't as pronounced on color displays but I've had polarized glass where monochrome displays totally disappears from sight.
Best check before buying if possible. Take the glass over to the electronics department and look at the various LCD units on display.
fast50
i have a pair of costa's with polarized prescription lenses and they are great
mike64
Addtional info.
I had heard that even the cheapest sunglasses offer sufficient UV protection.
But I don't want to give out bad info on something as important as eye protection, so I did a little googling and found out that there is a lot of variation in UV eye protection as dingbat says. Bottom line is to read the tag carefully.
Quote from the site straightdope.com:
"Tests of sunglasses have found wide variations in their effectiveness against UV, regardless of cost, tint color, or lens material. Ignore the sales hype and look for the following voluntary industry labels. "Cosmetic" sunglasses block 70 percent of the sun's most damaging rays, "general purpose" shades block 95 percent, and "special purpose" glasses block 99 percent. "UV-400," another label you often see, supposedly means the sunglasses block 100 percent of UV. A lot of experts recommend glasses in the latter two categories, the special purpose in this case being that they may keep you from going blind."
http://www.straightdope.com/columns...-the-risk-of-eye-damage-from-ultraviolet-rays
Quote from glaucoma.org:
"Don?t be deceived by color or cost. The ability to block UV light is not dependent on the darkness of the lens or the price tag. While both plastic and glass lenses absorb some UV light, UV absorption is improved by adding certain chemicals to the lens material during manufacturing or by applying special lens coatings. Always choose sunglasses that are labeled as blocking 99-100% of UV rays. Some manufacturers? labels say ?UV absorption up to 400nm.? This is the same thing as 100% UV absorption."
http://www.glaucoma.org/living/a_guide_to_sung.php
vabullet
I wear costa's man"o"wars but they run about $180 but i am on the water often. they are great for high speeds. great polaration also.My brother uses Wiley"X,s" and swears by them.They cost $80 bucks.Hope this helps.
scipper77
Maybe a little off topic but I want to get some clear polarized glasses. This is because I like to fish at sun up and sun down (or any time in between for that matter). Anyone know where I could find clear polarized lenses?
And to stay on topic, I use the walmart polarized glasses from the fishing section. Maybe I'll spring for a pricier pair this season.
JustJason
My 10 year old Oakleys still do a fantastic job of seeing through the water.
v8psp
I do like those, they look like costas. I might give them a try
