fuzzeywiggler
- Joined
- Feb 17, 2008
- 357
Re: Barracuda Restoration
Went and picked up supplies today I should have all the resin and cloth I need.
I also got foam he convinced my on doing the other method of foaming by pouring the foam into drilled holes beside the stringer because it holdes the deck much better as well as not having the hassel of installing the deck on the foam as well as the stringer.
An issue with pouring foam is the tempurature a lot of people are waiting for a warm day, but its not the air temp that counts but the foam temp that counts so put it under a heat lamp or inside untell its at least 70 C and it will be fine.
Heres what I got done today:
before I started the stringer
Heres how rotten the stringer was (mabey I shouldent of used the boat this season...)
