zuluwarrior
Thread starter- Joined
- Sep 11, 2010
- 109
Not sure this is going to work. Still a little unsure of the newer format.
Decided to have my stringers go all the way to the cabin entrance which means having stringers that will be longer than the 96" plywood length. The stringers will be approximately 155" long. So in doing some research on here I see that the best joint to use is a scarf joint to increase joint strength. So I found a easy to build scarf jig for a router and made one up. Have to say after the testing that this thing works pretty good.
