1997 5.7L thunderbolt ignition. Slow crank
findinghomer
Change cables and two starters doing the same thing would tell me it's not an electrical problem.
Have you checked the level of your oil, is it correct?
Remove the plugs and see if it cranks the same
Yes I have checked the oil before I even took it out. I didn't change it this year because I just changed it last year and only had it out about three times and it looked good still. So I just checked the level, It was fine. Also the plugs are already out of it.
I have even bypassed the dual switch and hooked both batteries up independently straight to the starter. Eliminating the cables from the switch. I've hooked a jump pack up to it no change, I've hooked a car with jumper cables up to it at one point it seemed like it was a little better but still slower than it should be. No matter what I do slow crank
nola mike
does it spin easily by hand?
findinghomer
I don't really know how to do that.. do you mean by turning the bottom pulley with a socket?
There is a 16 mm bolt on that pulley that I can't turn with a 3/8 ratchet. Should it turn easily with that? It feels like the bolt is tightening , I don't want to turn it too much and snap the bolt off lol
nola mike
Yes, good call, don't turn it like that. That bolt can snap. That said without plugs it shouldn't take much force (assuming you're in neutral). A few different ways to turn it, either by turning one of the accessory (alt, ps) pulleys, using a special tool, put a couple of bolts in the balancer and turn with a screwdriver wedged between, etc. If it doesn't turn easily at this point I'd pull the valve covers and make sure all of your valves are opening and pull the drive to take that out of the equation (although that seems unlikely if it's otherwise running well).
findinghomer
I did run voltage test. Here's what I found this is with each independent battery hooked directly to the starter no battery switch.
Batt 1: 12.4 volts at starter and battery when off, 9.5- 11 v At the battery when cranking, and 9.1 -9.5v at the starter.
Batt 2: 12.2 volts at starter and battery when off, 10v at battery when cranking, as low as 8.8v at the starter when cranking.
Both of these batteries will start my truck just fine, but is this a bad way to determine the battery having enough cranking power for the boat? My truck has a V8 in it, engine turns really strong with these batteries. And there both pass a load test at O'Reilly's. Or do you think it might be possible it's the batteries?
Sorry about my previous questions, you mention about pulling plugs
Could be your meter is off a tad (fully charge should be 12.7V), and you did have them tested.
Have you pulled the drive yet?
Could remove the belt going to the raw water pump so not to damage impeller, or connect hose to bell housing
findinghomer
I have not removed the drive yet. I'm going to get a new battery and see if anything changes. I did change out the positive battery cable to the starter no change. So now I have a brand new ground cable, a brand new power cable, And I have the battery connected directly to the starter I took the dual switch out . Both batteries tested and got a passing grade. And they both start my truck lol. I wonder if the starter I got is a dud but it's slow crank on both starters...
findinghomer
I have not changed my plugs in a long time but since I have them pulled I figured I would share their condition. Do they look rusted to you? The body on all of them that sits outside of the engine all have rust on them, but it doesn't look like they are rusted that goes into the motor. What do you think?
findinghomer
Plugs look fine, maybe a tad rich but nothing to worry about
Yeah and I know I'm running a little rich because I can't quite get it adjusted properly, but that's kind of what led me to all this. Hard start went hot. So when I got back for my 4th of July trip I started it on the muffs in the driveway and it fired up fine, I ran it to temperature and then shut it down. Because I wanted to come back out In 15 or 20 minutes and start it when it was warm. Of course it had a hard start , but at least it was cranking fine then it eventually started showing symptoms I'm behaving now, dead battery. But the battery isn't dead. I just went and hooked up my 2022 Highlander up to the boat through jumper cables. Doesn't help. I would think that's a sign of it definitely not being a battery, do you think it's a waste of time for me to go ahead and buy a new battery or do you think I should try it? This battery fires up my truck and it passed a load test at O'Reilly's and it's showing that it's fully charged. But I'm thinking maybe I should just buy a new battery before pulling the outdrive because I always have a hard time getting it back on
findinghomer
Yes, I have had the plugs out, when it still cranked slow, that's when I turned to the forums. I checked the oil oil looks good. I borrowed a new battery from my neighbor just to be sure it's not my batteries. Fully charged in 1 year old still won't turn. The only thing I haven't done is pull the outdrive. But before I do that I went ahead and ordered another starter. Just a couple things to note, the battery cables I made were out of 4 gauge wire not 2 gauge or zero gauge, but pretty sure the original ones were 6 gauge, at least the ones coming off of The switch were. And the starter that I put on was rated at 1.4kw not 1.7kw like the one I took off, so I went ahead and got another starter. Really hate changing that out too because it's difficult to get to but it's better than pulling the outdrive at this point lol. But I guess if three starters are still doing it, along with four different batteries a jump pack and jumper cables on a car, the only thing I got left is to pull the outdrive?
findinghomer
Could it have anything to do with the slave solenoid by the breaker?
This is just so hard to diagnose bc it happened out of nowhere, not coinciding with any particular incident. Ran fine all day and the next day, and then ran fine when I started it in the driveway got it to temperature, and then when I shut it off when I went to go start it is when I started having slow cranking out of the blue
nola mike
1. Ignore the plugs, they aren't the problem
2. Pulling the outdrive is waaay easier than swapping the starter. Didn't see whether its a bravo or alpha, but still...
3. Didn't see how hard it is to turn by hand yet
4. Plugs out there should be very little load on that starter. 9.1v is low. Starter voltage should be the same as the battery at all times. This still smells like wiring to me. 2 more tests that you can do.
a) Run jumper cables from battery to starter (keep other wires on there)
b) Voltage drop test: Set DVM to DC volts. To test pos: Put one lead on batt pos, other end on starter pos (doesn't matter which lead goes where). Crank engine. DVM should show little/no voltage. If it's more, that means you have too much resistance between batt and starter. Test the ground side the same way.
Also, does the cranking speed up as it turns? Maybe time for a vid?
findinghomer
Thanks for detailed response
1. Yeah I was just letting you know I pulled the plugs just to eliminate hydrolock
2. I can pull the starter and reinstall the starter in 20 minutes . it takes me about 5
hours to do the outdrive and most of the time I feel like I'm not going to get it back on But then somehow I get lucky and at the last second it finds its way in And it kills my back lol. It's an alpha Gen 2 btw
3. I don't have any tools to turn it by hand, but I was wondering if I can use a screwdriver and try to turn it at the flywheel where the starter engages, I have taken the starter back off. I'm getting a new one in tomorrow
4. Yes it does seem like it's something in the wiring because my voltage drop is severe it goes from over 12 volts to at times 8 volts . but I do want to reiterate the new wires I made are only 4 gauge because It's what I had on hand. But I put fresh terminals and they are cut to length. I can upgrade those if you think that will make a difference. The only reason I didn't order new cables is because the original cables were at least four gauge before anyway.
And for the separate test you're basically saying use jumper cables on top of the other cables hooked up? Just to give it some extra passage? Yeah I can try that I do have some really heavy duty cables. The cranking speed does not change it's just a constant slow crank , basically what you would expect out of 9 volts. But when you stop cranking the battery returns to normal 12 . 4 or higher .
But I got a new starter coming tomorrow I'll try the jumper cable idea then because I've already pulled the starter. I really appreciate you helping me through this, one question I did have the with the starter out, is it okay to try to turn the flywheel with a flat blade screwdriver by prying on it? If so how easy should it turn
tphoyt
If you dont need the starter for core take it apart just for kicks. Ran into this before and found a cracked magnet in the starter.
findinghomer
Hehe. I did that, and the starter I took off looked totally fine, I cleaned it up real good with brake cleaner and reassembled it. Works fine on the bench. But either way I have another one coming just to be safe And I sent the other new one I bought back.
