findinghomer
- Joined
- Nov 7, 2009
- 291
Yes I have checked the oil before I even took it out. I didn't change it this year because I just changed it last year and only had it out about three times and it looked good still. So I just checked the level, It was fine. Also the plugs are already out of it.Change cables and two starters doing the same thing would tell me it's not an electrical problem.
Have you checked the level of your oil, is it correct?
Remove the plugs and see if it cranks the same
I have even bypassed the dual switch and hooked both batteries up independently straight to the starter. Eliminating the cables from the switch. I've hooked a jump pack up to it no change, I've hooked a car with jumper cables up to it at one point it seemed like it was a little better but still slower than it should be. No matter what I do slow crank
