findinghomer
- Joined
- Nov 7, 2009
- 323
Okay thanks for corroborating, that was the only thing I was unsure of is if that voltage drop could be because the starter is drawing so much power against a seizing engine. I've been slowly getting it apart just kind of taking tips as I go lolIf you can’t turn the engine by hand, I’d also be leaning toward something mechanical. The voltage drop could just be the starter pulling hard against a locked engine. Since the cables worked fine the day before, I’d check the simple things first (starter, connections, possible hydraulic lock), but if those check out, internal damage seems likely.
