I was thinking about going that route, to upgrade to that I would just need to change the manifolds? I would just need to know what all I would need to purchase to make the vortec work, because the boat may not be worth putting all that money intoI would find out what it cost to rebuild it locally.
Could even find some vortec heads and have them installed while your at it
I'm not finding anything local with under 150k. There's some across the country I requested quotes on , under 100k miles, only a few that don't want more than remanYour old manifolds will work with vortec or non-vortec, no issues
The heads are what make a motor vortec. Newer blocks can have some added advantages but not enough that would change to get a newer block
If you find a good truck motor with low mileage that would be best, but even a higher mileage motor (not more than 100K) could still be ok if compression test out
Heads are the same so far as exhaust matting surface. You get more HP with vortecOh I thought I read on here the exhaust manifold from a non vortec won't bolt onto a vortec head? Does the vortec add HP?
I’d look into what it would cost to have it rebuilt locally. While you’re at it, it might be worth considering finding some Vortec heads and having them installed as part of the rebuild. It could be a good opportunity to upgrade things while everything is apart.
YesUpgrading to a vortec might be feasible and probably my easiest upgrade, because it would still bolt up to my stringers, And all of my Marine parts from my old engine would bolt up the same way right?
How do your stringers and transom look?
Any signs of rot?
Also. I have a 2BBL carb, will this manifold bolt onto a vortec? And will I have to run a different fuel pump or will the mechanical fuel pump work with it? Or have to contact them?Hey @Scott Danforth what do you think ?
Why wouldn't the mechanical work?The 2BBL isn't an issue but the manifold is, the Mans have different bolt patterns
Assuming you have a mechanical fuel pump so you would need to go electric
That's why I keep asking @Scott Danforth commentWhy wouldn't the mechanical work?
Exhaust ports same from 1954 to today. Manifold DOES NOT CAREOh I thought I read on here the exhaust manifold from a non vortec won't bolt onto a vortec head? Does the vortec add HP?
