Re: 1975 Starcraft 140 Evinrude OB -- Restoration IN PROGRESS FINALLY
So a little update again finally, if anyone is still keeping up on this slow moving thread.....
1. Have the tilt and trim torn down and cleaning it up inside and out for new paint and rebuilding it with all the new orings.
a. need to replace the wiring from the motor to the relay box as it is cut, cracked, exposed and oxidized.
b. anyone know what gauge the 3 wires are and where a good place to source some may be, that is not hurtful on the wallet?
2. If the weather holds out today, i will hopefully get the last coat on the pieces and be done with that.
3. like grandads carpeting of the bow and sides but no the cost of the aluminum. so i have some underlayment plywood, 11.00/sheet that will be used instead and coated/sealed with porch paint then wrapped in outdoor carpet.
4. cleaning the OB completely on the outside and sanding, filling in deep scratches in prep for paint.
That is the plan, as long as the rain stays away some more.
