View attachment 130922 Feels good don't it.... Hopefully I'll know 1 day soon too
I know you mean Bear about the grinding...CONGRATS on finishing it up
Now onto bigger and better things!!
Now for the fun and easy work![]()
Congrats on getting past suck-fest. You will revisit the grinder again from time to time, but nothing like this... Have a good rest and enjoy the accomplishment....
Congrats bro! Now you will find that the real itch begins when you go in/ near the boat without protection. I know I did. Keep finding light dust in places I wouldnt expect to.
That hull looks mighty clean to me though.
Great job bear .... that does suck but it's all done and my hat's off to you my friend for doing such a clean job. Great work!!
Uhhhmmm, I think you missed ONE LITTLE SPOT in the corner!
Man that is one Clean looking hull. Fantastic job. You'll be crusin on the fun stuff now. The powder will soon be forgotten.
nice job bear, now its time to start making it your boat!
No surprise that bear would have done pretty much the best clean-out job I've seen to date. Nice work.
Agreed, great job bear!
A third, so the motion carries....Best clean out 2012 goes to Bear, nice work.
almost a shame to put somehting back in a hull that clean........ excellent job, now one milestone down, transom is next...... keep up the momentum
Hi patrick.....
EDIT: DELETED A BIT TO SHORTEN IT...
Wrap it just like you would if you cut the entire glass skin of the transom off !!!!!
4 layers of alternating csm/1708 sandwiches.
The csm wraps should go around the bottom of the hull.....so you will have to do some fairing on the bottom side so you wont have a little hook right before the transom on the plaining surface.
Sleep peacefully my good friend...
It is going as it should !
Gonna replay vid one now for more questions.
Hey Gang...
So one thing at a time...
I have more than a few thin areas I've either chowed with the 24 grit :redface: or simply were not well glassed from the get go.. I'm thinking laying down some 1.5 oz. CSM in these areas (as most of existing glass appears to be woven mat) then 1-2 layers of 1708 for strength before I bed my stringers.
like this cool hole I decided to open up!
Yep, CSM Always between 1708 even though is has the CSM stitched to it. Your patch method is sound except for a bit of sanding and wash down with acetone.
80 Grit is fine. Not saying you Can't just saying acceptable practice is to always use a layer of CSM between. The Pros always lay CSM and then the cloth whether it has CSM backing or not. Now the 1708 was made so it was "One Stop Shopping but.... Two layers of CSM between layers of Cloth seems to always workout better.
two by two's and c-clamps to keep it flat.
