dizzyspots
- Joined
- Sep 21, 2007
- 87
Looks like they were repairing corroded section of hull under the original fuel tank...functional repair but ugly...and with steel components used...not a forever job I'm thinking
Can't mix to much with ketchup as it will water it down to much and it will run off. As for the soak, it depends on how bad the corrosion is. I used it on my trailer and left it on for 48 hours. Did an ok job for areas I couldn't get with a wire wheel.Just mix vinegar with ketchup...let it soak for how long...
Well its gonna get a longer ketchup soak than we planned. The track has a big event this weekend, so I cant get access till Monday at the earliest..so 144 hr soak!! Hah!Can't mix to much with ketchup as it will water it down to much and it will run off. As for the soak, it depends on how bad the corrosion is. I used it on my trailer and left it on for 48 hours. Did an ok job for areas I couldn't get with a wire wheel.
SHSU
Thinking about de-riveting the bottom edge of the transom where it meets the hull...building the .050 transom cover panel with a flange at the bottom, sliding that flange between the hull and the existing transom skin...epoxy between the entire two sheets, including the flange and another interior strip of .050 along the interior "ledge" solid rivet the whole thing together using the original rivet pattern...thoughts??You might want to form a new transom cover that has a lip or flange that can be attached to the bottom of the hull. Maybe an inside and outside piece. The inside could have the flange to attach to the hull the outside would provide support with a clean look, but not cause a drag in the water.
I was thinking to just overlay the existing and move out the next row of rivets. You could form something like this for the bottom part of the angle.Trying visualize the lower edge of that 3x4 angle that will be sitting on top of all those rivets...are you saying after adding fresh skin to the old transom as described...drill out all the old rivets and attach the 3x3 angle by resetting all those rivets and adding new lines of rivets thru the new skin to the angle...note: I do have access to an aircraft level sheet metal guy and a finger break ...
I do have a friend that is an expert fabricator...aircraft and racecars. .he's only seen these pictures... it is excited about the idea..he get eye calls on it next week...stay tuned!!Do you know a good tig welder? I’d definitely be adding another skin to the transom, but think I’d bite the bullet and have that seam welded with a little reinforcement. Maybe weld on some pods while your at it. Should offset any additional weight of a 4 stroke if you ever go that direction as well. Not the bottom feeder DIY we’d typically discuss here, but that damage needs a somewhat unconventional fix.
I would look for a stainless one, I know sea dog (I think is the name but may be wrong) has some stainless ones. I intend to use a stainless steel one on my Mariner after I add a new drain at the bottom and behind the transom support.my last boat had a Garboard brass drain...on a Mariner.. are u installing the rubber plug from the bilge side or outside...screw down or lever action? Thanks...headed out to do some more scrub and pressure wash...
I've only used the grey, never the white. I've always associated the white with glassers and the grey with tin boatsHull cleaned and ready for repairs...Marine Tex...white or grey? I see a price difference and specs are different. For the bond between riveted and/or bolted panels vs the areas for interior "skim coats" over cleaned pitting, which is preferred?? Cheers Mike
They're both suitable.Hull cleaned and ready for repairs...Marine Tex...white or grey? I see a price difference and specs are different. For the bond between riveted and/or bolted panels vs the areas for interior "skim coats" over cleaned pitting, which is preferred?? Cheers Mike
