Re: Do i need a drain port in the ski locker if I remove/cover the ski locker permant
View attachment 141544View attachment 141545View attachment 141546
Took some pics during lunch. As you can see, i do have some rot...but with fingers crossed my stringers are still good. Not likely right...LOL One of the pics show where i removed the seat base...no biggie.
Now bringing this back to my original problem area ... ski locker.
During lunch, I put the water hose at the drain of the ski locker. Water quickly filled up the ski locker. and barely drained to the bilge. There is an access hole shown in the below picture of the gas tank. the Water started rising there and barely trickled into the bilge. That tells me there is a blockage somewhere below the gas tank. So i lifted up the gas tank's end closest to the ski locker and water started flowing. Does this mean i need to remove the gas tank to clear the blockage? if so, is there a trick to it??? meaning will i need to get out the air pockets before putting it back together? is there something that I need to shut off or disconnect? Or is it simply disconnecting wires and hose and 'heeve hoeing' the tank out of the boat?
