I dont think it matters dealers choice. On my set up the lags were easier to get to with a wobble extension due to a side panel that made the bigger nuts harder to swing off.I've never pulled a motor by removing the screws holding the mount, always removed the top nuts and rear bolts. It might be easier to do so I just have never done it that way
Only thing I don't like about removing the lags is messing around with a penetration into wood. Mine are gooped in there pretty good with 4200 now.I dont think it matters dealers choice. On my set up the lags were easier to get to with a wobble extension due to a side panel that made the bigger nuts harder to swing off.
Oh, I didn't know that you align it while it was still hanging. I had planned on using my brother's shop to drop it in, then once I got it home worry about aligning it. I just wanted it to be dropped in real quick. Is that a problem to do it that way? Or is it just easier to do it while it's still hanging?It's not a thing. You hang the motor from the hook, and rear mounts. Align, then add the mounts, then realign
Yeah that's what I had taken into consideration, the only reason I did it last time was so that my alignment would be pretty close to where it was (ended up being exactly where it was didn't even need to align it) . That's why I was asking because this time I'm going to have to align it regardless..Only thing I don't like about removing the lags is messing around with a penetration into wood. Mine are gooped in there pretty good with 4200 now.
Okay thanks. I just needed to make sure it was possible without it hanging, because I might not have that option. I was just wanting to drop the motor in at my brother's mechanic shop and then take it home and deal with it from there. I didn't want to take up a whole bunch of their timeMuch easier when hanging, but possible without. Raising/lowering the front with a hoist is much quicker than turning the adjusters individually a turn at a time.
You do It either way but hanging is easier but I could shove my engine around when sitting on the engine mount stringersOh, I didn't know that you align it while it was still hanging. I had planned on using my brother's shop to drop it in, then once I got it home worry about aligning it. I just wanted it to be dropped in real quick. Is that a problem to do it that way? Or is it just easier to do it while it's still hanging?
