KathyD19
- Joined
- Jul 17, 2012
- 352
Re: '56 Johnson Javelin Shift/Throttle problem
Thanks for the quick reply...I've been checking back on here to see what words-o-wisdom you had for me!
I went to the hardware store to get PB Blaster since I'd heard that was best but they were out. I'll have to try another store this afternoon. Is an impact driver the same as a hammer drill? If so I have one of those! I bought anti-seize lube for whenever I put everything back together again. There was only a bit of water in the gear casing this time, but I hadn't replaced the gaskets on those two screws yet..I have new O rings on the screws now. I read about the importance of making sure the water pump housing and plate are very clean so I'll definitely take care of that. Someone mentioned putting some kind of lubricant on the new impeller so it isn't "run dry" the first time. Do you recommend doing that and if so, do I use gear grease or Vaseline? Also where do I apply the grease...just to the ends that will touch the sides or to the flat surfaces that will touch the housing plate?
Oh, on another note you'll love this: Had a repair guy out to the house to fix our A/C unit (which has had a leak since July that no one could find til now, when it's getting cold!) and he saw the LU sitting in the garage. He said "So what's your hubby working on?" And I said, "That's my project. I'm working on my boat motor." He gave me that "yeah, right" look and said "Oh really? YOUR project huh? What are you doing?" And I replied, "Well, I have to remove these screws to get to the water pump and replace the impeller then I'm going to flip it upside down so I can access the gear case and replace the clutch dog, the transmission was slipping out of forward into neutral." You could hear crickets chirp and his eyebrows just went up. I just smiled and he just nodded. Conversation over..point went to me.
