Another one...Upholstery
JDA1975
Re: Another one...Upholstery
trimjobber is great, I used him when I first started out, just be sure to order more than you need because if you underestimate chances are he will not have more of the same color.
one of my favorites is Upholstery Fabric, Wholesale and Discount Auto, Marine, and Furniture Upholstery Fabrics they give everyday folks the same wholesale prices I get, and anything you order you can get more of if you miscalculate. they are based out of Washington state so shipping times are longer for me, but I prefer them. I have about 10 regularly used vendors and they get 70% of my business
Woodonglass
JDA1975
Fun with foam....had to rebuild this car bench seats foam and springs, so I cut the 2" foam to fit the shape and added 1/2 foam over that smoother the edges...the seat cover also has 1/2" sew foam so makes a total of 3" of foam
This is the product I use to glue the foams together, you can get this in smaller size containers
Lay out the foam and fold it over, do half at a time
spray the adhesive on both pieces its contact adhesive so needs to be on both
after you have the top glued, cut the corners and apply glue to both sides of the cut
then pinch it together
then its ready for a cover
JDA1975
This is the type of gun I use to spray the glue, they are 29 bucks at lowes, so use em til they stop working and throw it away...as long as you keep it closed, the glue will stay sprayable for a long time
Test fitting the panel before adding the band
Band added and prepping to hog ring
perty...I enjoyed the pleating lay out on this one, the colors are not my favorite, but it does not matter what I think as long as customer likes it
Woodonglass
Sooo... being lazy and couldn't get the cover done too???? I'm gunna have to talk to the boss! OH I forgot you ARE the Boss!!!:embarassed:
JDA1975
lol you posted too early...i ran out of picture space on first one, so there!
Woodonglass
Like my Wife is always telling me...Timing IS EVERYTHING!!!!
JDA1975
Front seat finished, have to do the back seat still
all loaded up and ready to go home with a happy customer
Woodonglass
Can't wait to get the VW Bus seats to you!!! But I'm sure you'll make ME do ALL the work.
The Seats look absolutley GREAT!!!!!
MRS
I have a vinyl question just got vinyl from cabelas marine vinyl. But no fuzzy backing on it seems like good thick vinyl, should it have the fuzzy backing on it or does it matter?
Hey sweet job on the truck seat....
JDA1975
no, it does not need the fuzzy backing, in fact most of the vinyl I use does not have fuzzy backing...if you feel the need for a lil exra padding sew 1/8 in sew foam on before covering it...thanks for the compliment
MRS
Thank you for the reply was not sure but now alittle more practice and will go for it with the good stuff.:joyous:
Woodonglass
Are you saying the vinyl on the back side is just like the front side?? No Backing of any kind?
jimmy wise
Hey looking good.....what are you cutting foam with? I use a Bosch saw but also my band saw
JDA1975
Woody:
I believe he is talking about the backing...some vinyls have this fuzzy cotton-like backing....
JW:
I use my bandsaw or an electric carving knife....i just haven't been able to justify the cost of a foam cutter (electric carving knife with a plate)
NHGuy
Hey Judge very nice stuff! Question for you. What is the name of the plastic stripping that's used to anchor edges on upholstery? I am copying the original interior on my boat and found it used on some of the straight shots where colors change. In my sunpad there are 4 pads that are butted up against each other and the stripping is used between colors in there. It appears that it's there as both a hold down and to keep the lines straight.
JDA1975
Just sew a strip of vinyl into the seam allowance for the tiedown and staple it down...it will work the same, and gives you somewhere to use scraps that don't work anywhere else
MRS
Yes was talking about the backing does have backing just not the fuzzy stuff on it.
Now just need to practice sewing curves plus I keep sewing pieces together that I do not move out of the way.:facepalm:
But like they say practice makes better......
