banshee owner
Thread starter- Joined
- Sep 4, 2013
- 227
Re: banshee transom and likely stringers
basically the entire boat has foam with glass over it and im wondering how far back i should be cutting the deck just behind the last seat the deck has rot where fiberglass wasn't put on thick enough or something. its a shame the transom really isn't as bad as i anticipated the wood is soaked but only a 1/4 or so is rotted away completely (so far)
is there a maximum number of pics i can post i cant post anymore right now
Anyway my other problem is my transom is 1 3/4 thick without the fiberglass outerskin. problem is the plywood i have available is 3/4 inch thick so im wondering if should not worry about the last 1/4 inch or laminate two layers of 3/4 and one of 1/4 the use the thickness of fiberglass to gain up to 2 inches that the transom was originally.
first pic is the floor partially rotten last pics are the transom where one bad spot is
basically the entire boat has foam with glass over it and im wondering how far back i should be cutting the deck just behind the last seat the deck has rot where fiberglass wasn't put on thick enough or something. its a shame the transom really isn't as bad as i anticipated the wood is soaked but only a 1/4 or so is rotted away completely (so far)is there a maximum number of pics i can post i cant post anymore right now
