speete1011
- Joined
- Oct 1, 2005
- 20
Re: merc500 1973
Alex: Have you removed the idle tube from the carburetor and if so this tube we as a rule never remove unless extremely nessesary. If you have removed it and there is a crack in the brass tube then you should replace it, and saying that it maybe very difficult in getting this part it could very well be NLA and if so may aquired possibly through Tillitson Carburetors in Northern Ireland,GB which is a long way to go to find the part! The Model is stamped on the carburetor if you let me know I may be able to locate the correct part and send it to you, or check with Mercury Marine Ltd. I think they are located on 2395 Meadowpine Blvd. Mississauga, Ontario L5N 7W6 ask for "Leon" in Service/Warranty Department at 1-905-816-4751 this should be his direct line in! You can ask him if the part is still available and if not could you use an alternetive part!<br /><br />Help is here,help me help you!<br /><br />Read & Believe!!<br /><br />Merc!!!
