Need help with transom repair w/pics
kfa4303
Banned
Re: Need help with transom repair w/pics
Thanks ..... must be a Fender to be that color. That would look good.
Yup. You know it ;) '57 sea foam green, reissue strat. Good to see there's another git-tar guy here in the forums. Keep on pickin' and grinnin' :)
jbcurt00
Even this far from the house, looks like a great color from here!:D
sphelps
What was the paint formula Jon? Looks like MFG blue to me !:cool:
Jon Sob
Master Chief Petty Officer
Thanks Woody ... your advise on what colors to mix and how to do it was spot on.
Jon Sob
Hey sp .... I started with 2 tbs of white and 1/2 tsp of blue and mixed it till I got a color very close to the "Flamingo" and then I just started adding green till it looked close to what I wanted. It was not as complicated as I feared it would be. I don't think it has an actual color name since it was a custom mix. I mixed up a sample just to see how it looked on the boat but when I mix it for real I will try to remember to write down the actual formula. This is what I used:
Jon Sob
Thanks jb .... I have been waiting what seemed like forever to get to this point. Can't wait till she is all painted.
sphelps
Once the formula is down do we mix enough without hardener to do all of the coats then use as needed? How long will it keep without hardener? I was thinking about making extra for future touch up so the color would be perfect match . whatcha think?
Woodonglass
I kept very accurate measurements on my mixing ratio's and recorded them for my Flamingo Blue. If I had it to do over I would Mix a half Gallon without hardener. Buy a New empty can from Lowe's, make a plastic seal and drive the lid home. I think if you kept it in the house it would last a long time.
Jon Sob
My plan is to mix the colors together and then put 2 cups of paint into a mixing cup, add the hardener and thinner, mix it together as I need it. I will store the left over paint for touch up.
Woodonglass
Yeah, my problem was I calculated to well, and Had NO left over. I'm hoping when I'm ready to do the touch up on the chips to the bow, that my formula calculations will be spot on. We'll see.
Jon Sob
Ok ..... I know it is not a great shot but here she is with her first coat on. I am going to let her sit till morning and then I will sand her and start the second and hopefully the third coats. I painted the lower rub rail the same as the cap but not sure if I like it or not. The green is frog tape. I still have some white painting to do on the transom that is why it looks like that. I know I said this when I was painting the hull but I have to say it again ....... I will never make it as a body repair man. You sure see how well ( or how bad ) your sanding skills are when there is paint on ..... lol.
Woodonglass
I like the Splash Rail painted Blue!!!! From what I can see, she's looks pretty good in her 57 Chevy Blue Dress!!!!
GT1000000
Hey Jon, you say you wouldn't make it as a body man...I do it for a living, and let me tell you, there are guys doing this kind of work that don't come close to doing as nice a job as the one you are doing on your MFG...Like in all things in life, when you do it for the first few times, it is a learning curve, when you've done hundreds of times, you actually start to refine your techniques, and finally after thousands of times you are getting pretty close to knowing what you are doing...
If I remember correctly, you are in the same boat as most of us, this being your first restore...you are doing a fantastic piece of work...like those first few scratches and dings in the once new car or truck, after a while they become marks of pride from battles fought and survived...such are the little imperfections that creep up in our first few attempts at doing anything...
Brother, you are doing excellent, commendable, and inspiring work...Keep it up!
sphelps
I like the blue rub rail also when you pull the tape off it's gunna look good ! Just a little accent color.
Nice job Jon!!:)
TruckDrivingFool
I haven't looked in on this thread for quite awhile and I gotta say its come along way. It looks awesome with some color on it Jon!! Keep up the good work your rounding the corner.
Jon Sob
Thanks GT for the positive comments ..... as we all know they sure help in the motivation dept. I have a massive amount of respect for you guys that do that for a living. You have a very special talent.
Jon Sob
Thanks TDF ... Seemed like I would never get to that corner .... lol.
Woody, fst and sp ..... looks like you guys made it unanimous the blue rail stays.
Jon Sob
Does anyone know where I can get a good price on that seal along the bottom of the windshield?
