- Joined
- Oct 25, 2011
- 25,292
Re: 1968 starcraft hoilday 18 i/o 120
Were these guys 1 of the choices? Someone @iboats recommended them........
Man you really got after that thing. Nice to see no pour in foam as that was a real pain to remove. The contact cement is a pain to remove. In the end I think I used acetone to soften it up then took a stainless brush and/or razor blades to remove it but it took longer than I thought. MEK (Methyl Ethyl Ketone) will eat it up and make it waaay easier to remove but it's bad stuff so wear a mask.
My tank is an 18 gallon tank under the jump seat just to the left of the engine which works. I thought of the under deck tank at the time of the rebuild but I wanted to get on the water quick...which didn't happen![]()
Yes, it's a gm hei. That would explain some running issues I had 2 years ago. It had problems at high rpm, it would bog down. Of course it could have been a hundred other things also. At that time I wasn't too worried about it. I have already been pricing a ignition upgrade from summit anyway.Sounds like a great deal barring any big surprises. If you've got the time you can go through it from top to bottom. I was looking at the original engine pics late last night and it looks like a GM HEI distributor on there... I'd double check but it's probably not spark shielded the same as a marine part. The cl setup will probably have one anyway so another potential savings![]()
I don't think you want to use galvanized steel studs in an aluminum boat. For the same reason you don't use galv bolts for the tow eyes & motor thru bolts: Galvanic corrosion.
T3C - what are you looking to do with the floor? The original method isn't strong enough?![]()
Unless of course you are looking for an extra bit of bounce action on the floor with your new woman you will be taking out on the boat. Just sayin'
Well worth the money in my eyes. Never know, might find new women by next summer. Lol
Sounds like you might need to move to Utah :watermelon:
You're welcome, like I said, someone else found the gas tank lead, just passing the info along. Looks like a great place to design & adjust the design to meet capacity specs &/or space limitations. No matter who you use, if ya have a custom tank made, post details after you get the final product mounted & how the manufacturer was to work w/ (timely, communication, quality, fit & finish, etc) and if you get your money's worth.
I priced an apparently now discontinued bow tank by Moeller, sort of odd pie shape, 19gal, expensive $200+ ship. Evil-bay had 1 and although much more expensive then a low cost donor boat tank, it fit's how & where I intend to put it. And new, no rehab needed, so worth it to me.![]()
