1968 starcraft hoilday 18 i/o 120
GA_Boater
Re: 1968 starcraft hoilday 18 i/o 120
That's kind of a cool thought you put in his head Jason. 4.3 Alpha complete is 860lbs. If it's a Thunderbolt LX 4 barrel it's 205 hp:D The PO of my 201 said it went 65mph ( this has yet to be proven), should be an interesting project.
Isn't the 860 lbs including outdrive? I used to fly about 250 mph when I first got my tinny on the water. Then I turned on the GPS. :facepalm:
third times the charm
Well, I guess it's decided.:facepalm: 4.3 Starcraft it is. Will have to come up with a cool name or something for this mod.
Thanks for all the support fellows, you guys gave me the push I need to go with it:rolleyes:
Well I guess here's my first short list:
1: finish hull cleaning, get ready for gluvit
2: locate a rebuildable 4.3 or running( doesn't matter as I will go thru it regardless)
3: temporary mount my alpha one and test for fit( I thought Azlo did that and had to change something on the hole)
4: new transom
5: trailer rebuild, practice painting skills
6: fuel tank order???
Well that should keep me busy for a while, :facepalm:
jasoutside
I think you'll be just fine with that V6 in there. I'm not really a "go fast" boater and I really don't feel like yur over powered or anything. I do think she'll be lively n' fun though! :thumb:
(Course, I am thinking of the 175 horse version. If yur building out the 225 MPI version, wough baby:eek:nthego::flame:)
Yeah that 225 version would be a ball but that's more boot and pita wiring. I will stick with the 175 2 barrel carb version. Don't want it to cost me a fortune in fuel either.
GA_Boater
That 4.3 is from a dealer paying for the ad here. And no mention of any warranty. Plus shipping from Florida. A private seller is going to be a better deal with the same guarantee.
Okay so here's some thoughts I had today. I think we all know now that Jason is self proclaimed bottom feeder, and with his progress and projects I call bs, in a good way, but that's me. More like :first:
Now myself on the other hand, I will give the bottom feeders on here a run for thier money. So with that said...... Going to use my flat tank from the glasser, and make it a bow mounted tank. I have all that space under the cap that is just storage and figured that wont matter if I raise the floor there to make room for it. It's 28 gal, and best of all, I already have it. I think that will help keep my ballast even with the 6 cylinder upgrade. heres a name for thought, I will call her star scream maybe, sea trials will confirm I guess, in a year or two. I will put pics up this weekend of my tank idea.
Watermann
Star Scream, yeah the transformer and with that 4.3, shes more than meets the eye!
Well change of plans, it's cold down here,(yes I'm a wimp). Going to the new cabelas store with my old man tomorrow, then work on boat Sunday. It will be warmer:D. Ya have a good weekend
Okay well, didnt make it to cabelas, just reloaded some shells. So anyway.....
First and foremost:
A sacrifice to the tin gods, or maybe just a loan. :D
Alpha one outdrive removed and ready for a test fit
Tested fit in progress, major fail:facepalm:
Well here they are side by side. The one on the left is the alpha one, the one on the right is my mc-1 drive
So see the differences, the exhaust ports one are a different size,( v-6 vs. l4). Also notice a slight difference in the bolt spread. The bottom four holes are the same, then we get to the studs and the alphas are higher then my mc-1. So..... Will have to draw a new pattern from the glasser transom so I can re-cut the hole in the sc. I thought I was going to have to do that, no biggie. Worth it for the engine upgrade.
jbcurt00
Is the glasser destined to be crushed?
Just cut off the transom skin & use it as a pattern on the SC................
At this exact point, no crushing yet. Might repower with v-8 in a year or two down the ( after the sc) unless I find a islander, then yeah it's a crush job.
jbcurt00
When Jas shows up to help, tell him I'm sorry, I jumped the 'cut the transom off' gun ;)
Oh, he will be all disappointed, Get his hopes up for nothing. I can here his sawzall from here.:lol:
Okay so nothing fun today, just more cleaning the hull, prepping for gluvit.:whistle:
Before:
One side complete:
It's so shiny now:D
boatnut74
That 4.3 would be an awesome repower. I have pondered the idea myself for the SS. The only major factor would be mocking up motor mounts.
GA_Boater
Jason switched from an inline 4 to a 4.3 V6. Filling the Stringer sinkhole in the transom was a much bigger obstacle.
