- Joined
- Oct 25, 2011
- 25,329
Re: 1976 Century Arabian - Mercruiser 888 - Boat Restoration
Vinyl corner bead available in every state I've live in. That's for 35sticks 8' long. 1st 1 that came up w/ google.
If it's for channeling water along under the corner bead, novel & interesting approach that should work GREAT!
The pour in closed cell foam, probably won't 'let' water flow through it and into the holes & then draining into the channel, but it certainly is a good solution to a problem that has been tossed around many different ways.
Good idea, the only thing I don't like about it is, is that corner bead is metal covered with paper. I'd be worried about it rusting away, and causing issues.
