Woodonglass
- Joined
- Dec 29, 2009
- 25,933
Re: '89 Bayliner Avanti restoration - where to start?
Are you not planning on pulling the motor?
WOG, I have been suggesting to pull the motor in at least 3 of my posts. Motor has to come out to do a thorough job. the hour to pull the motor vs the 40 hours of trying to work around it is nuts.
89avanti - the original floor lasted 25 years with a small piece of scrap wood holding it together. following the same principle should give you another 25 years. However I like to over-build stuff, so I would run the backer the width of the boat.
The boat's still on the trailer right? You can still pull it around right? Gantry can be built in yard. Motor stand & Outdrive Stand can be built with wheels so after motor/outdrive are pulled and placed on stands they can be moved back to carport along with boat. We'll get you there!!!!
Where there's a will...There's a way!!!!
There should be a connector at the engine
