Re: First Boat Project
We have been getting a bit of work done over the last few day. We used the Bondo-Glass to fill in the holes, which I would not recommend. This stuff is too thick and the bits of fiberglass in it stick together so that you cant use a putty knife to scrap off the excess of it will just pull itself out of the hole some what. so what we had to do was glob a bunch in and on top of the hole then after it cured grind/sand it off. They did come out good, however, it just was more work than it should have been.
We also got the cap sanded with 320 grit paper to get her ready for primer and paint.
Also, we flipped the cap to work on the dash. The PO must have installed some sort of radio that was not the standard DIN size and it left a sloppy hole for it in the dash so we decided to make it bigger (and more square) to install our stereo. The issue was when the PO did this he took off a bunch of the wood in the dash so that it is almost just skin, so we had to reinforce this.
Another Thing I started to work on was this blue adhesive on the back of the splashwell. This was the stuff that gave us issues when taking the cap off. Its this rock hard light blue stiff and it is now mostly still on the back of the splash well. I have been using a hammer and wood chisel to try and get it off but I think I might just have to grind it off
We would have gotten more done but when I was cleaning the jet skiis to use this weekend I decided to hook up the hose to the flush kit on my Kawi 750sx and of course there is a leak between the exhaust manifold and the header pipe. And of course the gasket is coming the day im goin out.
