- Joined
- Jul 23, 2011
- 52,771
what did you set your dwell to?Alright I'm on the ocean right now....boat wont go over 2000 ram and can't get on plane....wth
what is your timing set to?
Ahhh, noDwell is at 30...as for timing I had dizzy loose and stopped were it ran the best
it was under load when you were trying to get past 2 k rpm. Point he was trying to make is if you set it by ear which is in accurate it is likely you may have timing too far advanced, which leads to detonation, which will burn a hole in a piston. Loads on marine engines produce a much higher detonation potential than in a car.I'm going to buy a new distributer....boat wasn't underload when I was setting distributer.
