Woodonglass
Honorary Supreme Mariner
- Joined
- Dec 29, 2009
- 25,933
Re: 1964 Johnson Tri-Hull restore!
Prime and paint it with some Rattle can Rustoleum. It'll seal it until your ready to do the hull.Got a little more done the past couple days. Got the rubrail on, need to pick up a little more hardware for that. Got the bilge and splash-well drains drilled and epoxied, I ended up epoxying a plastic pipe in the bilge drain, and the garbord drain will seal into that leaving no exposed wood!! Now just have to sand out a few areas on the hull I just filled with some fiberglass reinforced filler, seeing that I am not painting the boat, should I at least prime the repaired areas? and with what?
