quick glassing question
Trooper82
Re: quick glassing question
i really dont understande the difference between gelcoat and fiberglass, but im reading that build thread you pasted, cool non skid
Think of it like this....say you are gonna put up a barn....and want it to loook nice so have plans to paint it....
the fiberglass/resin is the wood in all of the different types you need to build it nice and strong....the gelcoat is the paint...
gelcoat is polyester resin (in most cases when talking about boat finishes) it just has pigments to give it color and it also uses a higher catalyst ratio, I always assumed to make it harder...but could be to allow for the catalyst to do it's job with all the extra ingredients?
Someone with better knowledge than I will steer ya straight....
Yacht Dr.
Gelcoat is the coating ( Paint ) .. Fiberglass is the surface.
Awlgrip or Gelcoat with griptex is a good finish. Both have their pro's and con's.
YD.
PS. I would use Awlgrip personally.
ondarvr
Gel coat is made of basically the stuff as resin, the biggest difference is that gel coat contains pigment.
You can use something other than gel coat and they can all work well, but you need to do the correct prep work for them to bond and they can be rather pricy. Gel coat will bond directly to your laminate with no prep at all, or sand as desired then apply it. Later touch up is rather easy if needed too.
Gel coat gives you a very hard finish, and depending on what you use to create the texture it can be like sand paper, which me be good or bad, just adjust the grit for the type of finish you want. You can apply it rather thick so it will last a long time.
Durabak works well and is softer than gel coat, you need to make sure you get the outdoor product though, or it won’t hold up. It’s nicer to walk on with bare feet and is less likely to take skin off if you slip. You need to prep the surface correctly.
Awlgrip is pricy, but goes on thinner so less is used, it’s hard and like gel coat you can adjust the texture by the grit you use. Being thinner it may wear through sooner. You need to prep the surface correctly.
KCKracker
ok i thought gelcoat was only for exterior. will both of these products stick well to fiberglass deck when im done?
Woodonglass
Gelcoat does not stick to Epoxy. Have you decided what you're going to use?
KCKracker
yes, sadly i walked into wets marine yesterday and saw epoxy resin was $104 a gallon. poly it is lol so the plan is
get filleting down,
then 1708 biax it will be tabbed with
then CSM on the deck and then cloth over.
last night i got half my sanding done today ill get the rest done then get her all cleaned out and the hull wiped down good
what do you suggest the wiping down of dust with? acetone?
Woodonglass
Shop Vac it out, Wipe down with wet towels. Dry, then Final wipe down with Acetone.
KCKracker
ok thanks! i think im going to go ahead and sand / clean my bilge and paint that too so i can see down in that black hole lol. im thinking Rustoleum enamel in white might be a good inexpensive choice :first:
Raist11
Okay, this confuzzled me but let's see if I can get this right. Gelcoat won't stick to epoxy.. but most people use epoxy? BUT, have I read that people will put a wax finish (of some sort) over the epoxy so that the gelcoat will stick? Or am I totally drunk?
I don't mean to hijack, I don't think it really is.. just want to clarify the statement.
jbcurt00
The part I bolded ^^^ is correct, the rest isn't
Most don't use epoxy
Wax isn't applied over epoxy, and again gelcoat won't stick to epoxy
Please try to refrain from hijacking
KCKracker
I have hijacked my own thread, thoughts on this? :joyous:
jbcurt00
Rusto isn't typically fuel resistant. So........
BilgeKot/gelcoat/duraback and maybe awlgrip too
KCKracker
weird i just did some searching for and saw where WOG suggested what i was thinking. plus home depot is close to me lol, well darn ok.
Raist11
Good, thanks.
As I mentioned, I don't think it was really hijacking. Since it was on topic and not deviating from KCCracker's question. I was merely looking for clarification on WOG's answer. But not asking anything about my own project. It seemed silly to create a new thread to ask about an answer in another thread. As we are told, read all the threads to learn. :)
KCKracker
this thread has discussed epoxy and gelcoat, far from a hijack, and i could care less its just more info for me anyways lol. hey JB it just hit me, dont have any chemicals in my bilge, im outboard :laugh:
jbcurt00
KC: Where's the fuel can going to go?
Raist: Check your thread for a detailed reply to your question @epoxy, wax & etc
jbcurt00
I suspect this is similar to what you are referring to:
Rustoleum Professional oil based paint with acrylic enamel hardener. $50 bucks for paint and hardener.
From here:
what kind of bilge paint and topcoat paint to use on top of epoxy
That ^^^ isn't typical Rusto, and it isn't just the Rusto. The hardener changes the paint drastically, and is EXTREMELY hazardous to your health. Extreme precautions must be taken when using an iso hardener, esp when sprayed.
I wouldn't recommend you use it.
When dealing w/ boat resto, epoxy, poly resin, gelcoat & paint the devil is in the details. You've got to be paying attention & try extremely hard not to miss anything. What you miss might be critical to the products success and more importantly the boat & your safety.
And that's ^^^ what I was suggesting yesterday about deck finishes. Not a decision to be made quickly, there is lots to consider.
KCKracker
fuel tank is in the floor. yes that was the thread i found, thanks for all the info I will just grab a gallon of BilgeKote and do it the easy way so i can spread it and forget it :)
mwe-maxxowner
Master Chief Petty Officer
I would recommend the bilge coat as well. Iboats has the petit bilge coat very cheap. It is easy to work with, and I like it. Just be sure to roll on thin coats and don't let it pool anywhere. If it puddles up in a spot that spot stays soft and doesn't harden properly.
ondarvr
If you want to paint the bilge, use gel coat, there will be no special prep work, it will hold up to anything, plus you will already have it on hand. Keep it simple.
