maxum247
Thread starter- Joined
- Sep 18, 2007
- 1,363
Re: Inboard outboard air cooled engine
If you look at the bottom of the boat where the lower unit comes thru you can see the vent screw coming just below the bottom of the boat. To fasten the cavatation plate hard to the hull I would need to move the lower unit up 1/2 inch, I would only have to unfasten 6 screws inside the boat that hold the angle bracket in place, move the angle bracket up 1/2 inch and screw it back into place. I would need to cut 1/4 - 3/8 inch off the drive shaft and coupling, then the vent screw would be up where I could get to it no problem, to fix this sounds worse than it would be to actually do it, probably could have it done in an hours time if I got right on it!
The only problem with putting the lower unit hard against the bottom is, the way I had to cut the hole through the bottom to get the lower unit in, there's nothing to really bolt to, so that's the reason for the question about cutting the cavatation plate flush with the housing and why the wood blocks were originally there. This way I could let the angle bracket hold the unit in place as it does now and flip the boat and mold around the lower unit, get the shape that I would want and then glass over it for a good strong water tight seal. I think I'll be able to remove a little chunk from the hull and it will be a fine fix, and if I dress up the bottom correctly the little bump out shouldn,t even be noticeable! Sorrry for the confusion.
In the picture you can see part of the gap I'm talking about, if the plate were removed it would be a nice smooth transition for the fiberglass to mold to.
Can I cut the cavatation plate safely without weakening the lower unit?
Ok, got this Pic from Post #175 bottom of page #7, is this the vent screw at the top of the Pic that you're talking about? If so, wouldn't it be accessable if you fastened the Cav plate hard to the hull, I mean all you're gonna do is take it out to vent? I would try, & do it that way, even if I had to grind off some of the boat bottom. If you need some tips as to how I would seal it all up let me know later.
